[GRASS-dev] gis.m: cannot get profile from profile tool
Patton, Eric epatton at nrcan.gc.ca
Mon Jul 31 22:23:45 EDT 2006
Michael,
I'm confused; I selected a raster via the first button from the left on the
profiling GUI (See the image on my ftp site); in the bottom left corner of
the profiling GUI, the text reads "Profile for CheticampAll_Aug2005_10m"
(the bathymetry raster I'm profiling.)
I'm at home now so I can't use Grass until tomorrow morning, but just to
make sure I'm using it correctly, you click the first button on the left to
load a raster to profile, the second to draw a profile in the profile
window, and the third to render the profile graph?
~ Eric.
-----Original Message-----
To: Patton, Eric; Moritz Lennert
Cc: 'Grass Developers List '; Markus Neteler
Sent: 7/31/2006 3:17 PM
Subject: Re: [GRASS-dev] gis.m: cannot get profile from profile tool
Eric,
You failed to select a raster map to profile.
I just committed an update which does a better job of trapping this kind
of
error and giving you a more meaningful error message. I also made the
profiler default to the currently selected raster map to profile and
also
found a way of making the elevation ranges calculated within the
currently
displayed region, using r.univar. The primary drawback of this is that
it is
a bit slow to get started with enormous maps.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: "Patton, Eric" <epatton at nrcan.gc.ca>
> Date: Mon, 31 Jul 2006 12:52:01 -0300
> To: 'Moritz Lennert ' <mlennert at club.worldonline.be>, 'Michael Barton
> <michael.barton at asu.edu>
> Cc: 'Grass Developers List ' <grass-dev at grass.itc.it>
> Subject: RE: [GRASS-dev] gis.m: cannot get profile from profile tool
> Hi guys,
> I tried the porfiling tool with July 31 cvs, and I can't get it to
work. The
> y-axis gets assigned correct values for the profile I've drawn, but no
lines
> get drawn in the profile window. A tcltk window reports "Error: can't
read
> "cumdist": no such variable"
> You can view the output on my ftp site:
> ftp://agc.bio.ns.ca/outgoing/Patton/Grass/Bug%20Reports/
> ~ Eric.
> From: grass-dev-bounces at grass.itc.it
> To: Michael Barton
> Cc: Grass Developers List
> Sent: 7/27/2006 2:33 AM
> Michael Barton wrote:
>> Hi Moritz,
>> Did you select a raster to profile?
> Yes, as you can see in the screenshot, it says in the bottom left:
> "Profile for srtm_be".
>> Third button from the left on the
>> profiler toolbar.
>> Rather like d.profile, the profiler differentiates between
>> a map you use as a background to the profiling line (what is shown in
> the
>> map display) and the map that you actually use to compute profile
> values.
> I understand that, but I still don't get a profile. Actually, I
> sometimes do not even get the straight blue line you see in the
> screenshot (http://moritz.homelinux.org/grass/gism_profile.png), just
an
> empty graph.
> The min and max of the heights on the y axis seem correct, though.
> Moritz
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
