[GRASS-dev] [bug #4522] (grass) r.series: error in row of input map is non-fatal giving wrong results
Thu Jun 1 01:31:36 EDT 2006
> I suggest that:
> a) G_get_raster_row() etc should automatically call G_fatal_error() if
> an error occurs, with a function to disable this behaviour for modules
> which really need to do their own error handling.
ok
> b) It should be the library's responsibility to clean up incomplete
> maps upon exit.
> Having to manually check for error conditions and perform clean-up
> whenever an error occurs is enough of a nuisance that it will
> frequently be omitted (or, if error handling is added, those code
> paths will seldom get tested and thus will frequently contain bugs).
does that mean you have to start sending the file descriptors, etc,
along to the lib fns? While one read error probably means many, waiting
for cleanup-on-GRASS-exit seems less messy somehow.
Should G_get_raster_row() do system("$GISBASE/etc/clean_temp") before
calling G_fatal_error() ?
Hamish
