Huidae Cho wrote: > While editing the operator precedence table in r.mapcalc.html, I found that > operators with higher precedence have HIGHER numbers. Shouldn't the highest > precedence have the lowest number or 1? That's the usual convention. -- Glynn Clements <glynn at gclements.plus.com>
