[GRASS-dev] r.mapcalc operator precedence table
Huidae Cho
grass4u at gmail.com
Tue Jun 6 01:21:15 EDT 2006
On Tue, Jun 06, 2006 at 05:56:08AM +0100, Glynn Clements wrote:
> Huidae Cho wrote:
> > While editing the operator precedence table in r.mapcalc.html, I found that
> > operators with higher precedence have HIGHER numbers. Shouldn't the highest
> > precedence have the lowest number or 1?
> That's the usual convention.
You mean the convention is that the higher precedence has the higher number?
Huidae Cho
