[GRASS-dev] A portible shell for GRASS 7+ ?
Wolfgang Zillig
wollez at gmx.net
Fri Jun 9 07:01:35 EDT 2006
If I understand correctly, the only limit is the X-server to run Grass
on native windows?
Wolfgang
Laurent C. schrieb:
> 2006/6/9, Wolfgang <wollez at gmx.net <mailto:wollez at gmx.net>>:
> Hi all,
> I'm not an developer but a user of grass and I'm working on grass for
> cygwin and I would prefer to get rid of cygwin, because I only need it
> to run grass. But I don't think the windows command line is
> extendable
> in a way that it is fully compatible with bash (even if all packages
> from gnuwin32 (gnuwin32.sf.net <http://gnuwin32.sf.net>) are
> installed). So I would like to have
> an alternative shell for grass.
> Cheers
> Wolfgang
> Hello,
> Bash isn't in gnuwin32 packages, but it run natively under Windows.
> http://www.steve.org.uk/Software/bash/
> <http://www.steve.org.uk/Software/bash/>
> Laurent
