[GRASS-dev] A portible shell for GRASS 7+ ?
Laurent C.
lrntct at gmail.com
Fri Jun 9 08:14:25 EDT 2006
2006/6/9, Wolfgang Zillig <wollez at gmx.net>:
> If I understand correctly, the only limit is the X-server to run Grass
> on native windows?
> Wolfgang
AFAIK, yes. That why a lot of work is made to remplace the actual tool which
need X11, like v.digit and so on. For example, Radim made a qgis-grass
binary for windows which work quite well.
Laurent C. schrieb:
> > 2006/6/9, Wolfgang <wollez at gmx.net <mailto:wollez at gmx.net>>:
> > Hi all,
> > I'm not an developer but a user of grass and I'm working on grass
> for
> > cygwin and I would prefer to get rid of cygwin, because I only need
> it
> > to run grass. But I don't think the windows command line is
> > extendable
> > in a way that it is fully compatible with bash (even if all packages
> > from gnuwin32 (gnuwin32.sf.net <http://gnuwin32.sf.net>) are
> > installed). So I would like to have
> > an alternative shell for grass.
> > Cheers
> > Wolfgang
> > Hello,
> > Bash isn't in gnuwin32 packages, but it run natively under Windows.
> > http://www.steve.org.uk/Software/bash/
> > <http://www.steve.org.uk/Software/bash/>
> > Laurent
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060609/9c0995d4/attachment.html
