[GRASS-dev] A portible shell for GRASS 7+ ?
Michael Barton michael.barton at asu.edu
Fri Jun 9 12:43:20 EDT 2006
I¹ve run the current GIS Manager in Aqua TclTk with the bash terminal and no
x11 using Lorenzo¹s binaries. It runs fine as long as  you don¹t start
something that requires x11 (e.g. i.points, v.digit, d.profile, nviz). The
new georectifier and profiler work without x11, and so should work fine.
If someone could compile the existing Windows native code with the d.modules
and gis.m intact, and start it up using native Windows wish it should run
theoretically. But I don¹t know how to do this and so can¹t test it. It
would be good to know if our efforts in this direction are helpful, though.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
Date: Fri, 9 Jun 2006 14:14:25 +0200
To: Wolfgang Zillig <wollez at gmx.net>
Cc: grass-devel <grass-dev at grass.itc.it>
Subject: Re: [GRASS-dev] A portible shell for GRASS 7+ ?
2006/6/9, Wolfgang Zillig <wollez at gmx.net>:
> If I understand correctly, the only limit is the X-server to run Grass
> on native windows?
> Wolfgang
AFAIK, yes. That why a lot of work is made to remplace the actual tool which
need X11, like v.digit and so on. For example, Radim made a qgis-grass
binary for windows which work quite well.
> Laurent C. schrieb:
>> > 2006/6/9, Wolfgang <wollez at gmx.net <mailto:wollez at gmx.net>>:
>> >     Hi all,
>> >     I'm not an developer but a user of grass and I'm working on grass for
>> >     cygwin and I would prefer to get rid of cygwin, because I only need it
>> >     to run grass. But I don't think the windows command line is
>> >     extendable
>> >     in a way that it is fully compatible with bash (even if all packages
>> >     from gnuwin32 (gnuwin32.sf.net <http://gnuwin32.sf.net>
>> <http://gnuwin32.sf.net>) are
>> >     installed). So I would like to have
>> >     an alternative shell for grass.
>> >     Cheers
>> >     Wolfgang
>> > Hello,
>> > Bash isn't in gnuwin32 packages, but it run natively under Windows.
>> > http://www.steve.org.uk/Software/bash/
>> > <http://www.steve.org.uk/Software/bash/>
>> > Laurent
> grass-dev mailing list
> http://grass.itc.it/mailman/listinfo/grass-dev
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20060609/2fde08a3/attachment.html
