[GRASS-dev] grass6.2?
Michael Barton
michael.barton at asu.edu
Sat Jun 10 01:46:37 EDT 2006
What about geometry? We have to stop d.mon gism, reset the geometry, and
restart gism. How is this handled in the new system?
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Sat, 10 Jun 2006 02:30:32 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] grass6.2?
> Michael Barton wrote:
>>> So, should I commit the changes to libraster to allow driver-less
>>> rendering?
>> Does this mean that I can change gis.m to render with out running d.mon?
> Yes.
>> Anything I would have to know about setting environments to do this?
> If the environment variable GRASS_RENDER_IMMEDIATE is set to TRUE,
> libraster uses the built-in "PNG driver" instead of connecting to a
> monitor. All of the environment variables which the PNG driver
> understands apply to immediate rendering.
> This should be backwards-compatible, i.e. so long as you don't set
> GRASS_RENDER_IMMEDIATE, everything should work as before.
> I've attached the code in case anyone wants to try it now.
