[GRASS-dev] grass6.2?
Glynn Clements
glynn at gclements.plus.com
Fri Jun 9 21:30:32 EDT 2006
Michael Barton wrote:
> > So, should I commit the changes to libraster to allow driver-less
> > rendering?
> Does this mean that I can change gis.m to render with out running d.mon?
Yes.
> Anything I would have to know about setting environments to do this?
If the environment variable GRASS_RENDER_IMMEDIATE is set to TRUE,
libraster uses the built-in "PNG driver" instead of connecting to a
monitor. All of the environment variables which the PNG driver
understands apply to immediate rendering.
This should be backwards-compatible, i.e. so long as you don't set
GRASS_RENDER_IMMEDIATE, everything should work as before.
I've attached the code in case anyone wants to try it now.
Type: application/octet-stream
Desc: driver-less libraster
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060610/16bcbc75/libraster.tar.obj
