[GRASS-dev] grass6.2?
Michael Barton
michael.barton at asu.edu
Mon Jun 12 12:37:30 EDT 2006
Markus,
Are these in the cvs as part of the normal compilation? If so, they should
go into the menu.
I've been tied up in other stuff and so haven't updated the menu much
lately. Also, I was unsure how to do it after Cedric's changes (still unsure
about a few issues).
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics and Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Markus Neteler <neteler at itc.it>
> Date: Mon, 12 Jun 2006 09:34:23 +0200
> To: <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] grass6.2?
> Michael,
> just curious: do you intend to also include the
> new developments:
> - homology based rectification with lines
> - Fourier correlation based auto search of GCPs
> See:
> http://grass.itc.it/pipermail/grass-dev/2006-March/022051.html
> for link to the source code.
> Markus
> On Sun, Jun 11, 2006 at 11:51:13PM -0700, Michael Barton wrote:
>> Is there a reason to change i.rectify at some point so that it also will
>> read from a different directory and write to the current one? This is how
>> the georectifier works, but I have to switch back and forth between
>> locations/mapsets to make i.rectify work.
>> I have no idea about the locking. But probably not or I would have probably
>> run into it like I did with g.mapset.
>> Michael
>> Center for Social Dynamics & Complexity
>> phone: 480-965-6213
>> fax: 480-965-7671
