[GRASS-dev] grass6.2?
Markus Neteler neteler at itc.it
Mon Jun 12 12:40:13 EDT 2006
Michael,
no, the new functions aren't yet in CVS:
I wrote:
Not related to GUI, but related to a new i.points (as long time promised):
http://mpa.itc.it/markus/tmp/i.points.auto_30_mar_2006.tar.gz
This should be the merge of i.points + i.vpoints along with
homography support (geocoding by lines instead of points which is
much easier/faster) and auto-GPC search (based on Fourier correlation).
There is a file HANDBOOK inside which explains it a bit. Today
I found some raster-map negative row bug, maybe someone wants to give it
a try? Would be fun to have that in GRASS soon.
So a couple of files (a few) need to the added/modified in i.points to
get that functionality.
Markus
Michael Barton wrote on 06/12/2006 06:37 PM:
>Markus,
>Are these in the cvs as part of the normal compilation? If so, they should
>go into the menu.
>I've been tied up in other stuff and so haven't updated the menu much
>lately. Also, I was unsure how to do it after Cedric's changes (still unsure
>about a few issues).
>Michael
>__________________________________________
>Michael Barton, Professor of Anthropology
>School of Human Evolution & Social Change
>Center for Social Dynamics and Complexity
>Arizona State University
>phone: 480-965-6213
>fax: 480-965-7671
>www: http://www.public.asu.edu/~cmbarton
>>From: Markus Neteler <neteler at itc.it>
>>Date: Mon, 12 Jun 2006 09:34:23 +0200
>>To: <grass-dev at grass.itc.it>
>>Subject: Re: [GRASS-dev] grass6.2?
>>Michael,
>>just curious: do you intend to also include the
>>new developments:
>>- homology based rectification with lines
>>- Fourier correlation based auto search of GCPs
>>See:
>>http://grass.itc.it/pipermail/grass-dev/2006-March/022051.html
>>for link to the source code.
>>Markus
>>On Sun, Jun 11, 2006 at 11:51:13PM -0700, Michael Barton wrote:
>>>Is there a reason to change i.rectify at some point so that it also will
>>>read from a different directory and write to the current one? This is how
>>>the georectifier works, but I have to switch back and forth between
>>>locations/mapsets to make i.rectify work.
>>>I have no idea about the locking. But probably not or I would have probably
>>>run into it like I did with g.mapset.
>>>Michael
>>>Center for Social Dynamics & Complexity
>>>phone: 480-965-6213
>>>fax: 480-965-7671
