[GRASS-dev] TOGL issue - was Re: nviz link broken
Mon Jun 12 19:55:54 EDT 2006
Markus Neteler wrote:
> > > http://grass.itc.it/grass61/manuals/html61_user/
> > > nviz link is broken?
> > Yes. This means that the compilation of the Linux snapshot failed.
> > Verification:
> >  http://grass.itc.it/grass61/binary/linux/snapshot/error.log
> >  -> apparently there are/were compilation issues.
> > I can try to investigate.
> Done:
> make[3]: Entering directory `/hardmnt/krokus0/neteler/grass61binarybuild/grass6/grass6/visualization/nviz/src'
> gcc -I/hardmnt/krokus0/neteler/grass61binarybuild/grass6/grass6/dist.x86_64-unknown-linux-gnu/include  -O2       -I/hardmnt/krokus0/neteler/grass61binarybuild/grass6/grass6/dist.x86_64-unknown-linux-gnu/include    -I/usr/local/include  -DUSE_X11=    -DPACKAGE=\""grassmods"\"  -I/hardmnt/krokus0/neteler/grass61binarybuild/grass6/grass6/dist.x86_64-unknown-linux-gnu/include \
>         -o OBJ.x86_64-unknown-linux-gnu/nvizAppInit.o -c nvizAppInit.c
Note: -DUSE_X11=
This should be -DUSE_X11=1 if configure detected X.
> In file included from togl.h:16,
>                  from nvizAppInit.c:8:
> togl_ws.h:5:12: #if with no expression
Hmm. I'll need to change the Makefile for that. USE_X11 is either 1 or
empty, which isn't easy to test for in a #if directive.
> In file included from nvizAppInit.c:8:
> togl.h:51:27: OpenGL/gl.h: No such file or directory
Due to the USE_X11 test failing, Togl thinks it's being compiled for a
Mac.
> I guess I missed the related discussion recently.
> According to the ChangeLog it is related to Glynn's TOGL
> update.
It is. However, the fact that USE_X11 isn't getting set is the root of
the problem.
