[GRASS-dev] TOGL issue - was Re: nviz link broken
Markus Neteler
neteler at itc.it
Tue Jun 13 04:03:39 EDT 2006
Glynn Clements wrote on 06/13/2006 01:55 AM:
>Markus Neteler wrote:
>>>>http://grass.itc.it/grass61/manuals/html61_user/
>>>>nviz link is broken?
>>>Yes. This means that the compilation of the Linux snapshot failed.
>>>Verification:
>>> http://grass.itc.it/grass61/binary/linux/snapshot/error.log
>>> -> apparently there are/were compilation issues.
>>>I can try to investigate.
>>Done:
>>make[3]: Entering directory `/hardmnt/krokus0/neteler/grass61binarybuild/grass6/grass6/visualization/nviz/src'
>>gcc -I/hardmnt/krokus0/neteler/grass61binarybuild/grass6/grass6/dist.x86_64-unknown-linux-gnu/include -O2 -I/hardmnt/krokus0/neteler/grass61binarybuild/grass6/grass6/dist.x86_64-unknown-linux-gnu/include -I/usr/local/include -DUSE_X11= -DPACKAGE=\""grassmods"\" -I/hardmnt/krokus0/neteler/grass61binarybuild/grass6/grass6/dist.x86_64-unknown-linux-gnu/include \
>> -o OBJ.x86_64-unknown-linux-gnu/nvizAppInit.o -c nvizAppInit.c
>Note: -DUSE_X11=
>This should be -DUSE_X11=1 if configure detected X.
>>In file included from togl.h:16,
>> from nvizAppInit.c:8:
>>togl_ws.h:5:12: #if with no expression
>Hmm. I'll need to change the Makefile for that. USE_X11 is either 1 or
>empty, which isn't easy to test for in a #if directive.
Thanks, now it reports:
gcc
-O2
-I/usr/local/include -DUSE_X11=0 -DPACKAGE=\""grassmods"\"
In file included from nvizAppInit.c:8:
togl.h:51:27: OpenGL/gl.h: No such file or directory
-> -DUSE_X11=0
which is at least easier to test.
>Due to the USE_X11 test failing, Togl thinks it's being compiled for a
>Mac.
>>I guess I missed the related discussion recently.
>>According to the ChangeLog it is related to Glynn's TOGL
>>update.
>It is. However, the fact that USE_X11 isn't getting set is the root of
>the problem.
checking whether setpgrp takes no argument... yes
checking for W11... no
checking for X... no
checking whether to use Curses... yes
checking for curses.h... yes
HA! I'll check if X is installed, apparently only partially on the new
server...
rpm -qa | grep xorg
xorg-x11-Mesa-libGLU-6.8.2-1.EL.13.25
xorg-x11-deprecated-libs-devel-6.8.2-1.EL.13.25
xorg-x11-libs-6.8.2-1.EL.13.25
xorg-x11-devel-6.8.2-1.EL.13.25
xorg-x11-Mesa-libGL-6.8.2-1.EL.13.25
xorg-x11-deprecated-libs-6.8.2-1.EL.13.25
xorg-x11-xauth-6.8.2-1.EL.13.25.1
I'll check.
Markus
