[GRASS-dev] making py.monitor listen to external commands
Jachym Cepicky jachym.cepicky at centrum.cz
Wed Jun 14 14:52:56 EDT 2006
Hallo,
bugfix version of py.monitor scripts. Some people tested the scripts and
they found it nice. What about you, developers?
Current version avaliable on
http://les-ejk.cz/programs/grass/py.monitor-06-06-14-4.tgz
tar xzf py.monitor-06-06-14-4.tgz
cd py.monitor
py.mon start=py0
py.rast soils -o
py.vect roads
py.erase
Everything, what should work (all toolbar buttons, etc.) works. Zoom/Unzoom
avaliable via mouse wheel. Mapcontent manageable via py.* commands (this
should move to d.* commands in the future) from commandline and via any
other interface via LOCATION/MAPSET/.pyX file.
Starting with the morning, I will not have much time and I will not be
so close to internet for a week, so I will not spam your mailboxes
for a while.
It would be good just to send me some note, e.g., that you tryed, but it did
not work. It is not so easy to develop GUI without any  feedback.
Looking forward
Jachym
On Wed, Jun 14, 2006 at 11:34:09AM +0200, Jachym Cepicky wrote:
> Hallo,
> after long discussion with Michael and a bit coding, I would like to
> present new new concept of GRASS monitors.
> I prepared set of py.* commands, which IMHO *should* became parts of d.*
> commands. This is just a workaround this.
> General concept is, each monitor has it's own LOCATION/MAPSET/.pyX file,
> in which the d.* files are stored. This file is checked from the GUI and
> if there is some change, it's content serves for creating the map.
> Advantage of this approach is, that this file can be modified from any
> GUI/CLI. Target is, to have py.mons *independent* on any UI, however
> managable from *any* of them.
> Screenshot can be found on [1], set of new tools can be found on [2].
> Example session (in xterm) can look like follows:
> py.mon start=x0
> py.mon start=py0
> py.rast soils
> py.vect roads
> py.ctrl -l
> py.ctrl remove=vect
> py.rast fields -o
> py.vect fields fcol=yellow
> py.ctrl -l
> (see screenshot [1] for details and possible outputs).
> py.rast and py.vect commands can be used just like the old d.* commands
> for installation just untar [2] and cd new py.monitor directory
> [1] http://les-ejk.cz/tmp/py.mon.png
> [2] http://les-ejk.cz/programs/grass/py.monitor.tgz
> Please test and discusse.
> Jachym
> Jachym Cepicky
> e-mail: jachym.cepicky at centrum.cz
> URL: http://les-ejk.cz
> GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
> OFFICE:
> GDF-Hannover
> Mengendamm 16d
> 30177 Hannover
> Germany
> e-mail: cepicky at gdf-hannover.de
> URL:    http://gdf-hannover.de
> Tel.:   +49 511-39088507
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Jachym Cepicky
OFFICE:
GDF-Hannover
Mengendamm 16d
30177 Hannover
Germany
Name: not available
Desc: Digital signature
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20060614/fb73cc41/attachment.bin
