[GRASS-dev] making py.monitor listen to external commands
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Thu Jun 15 04:16:14 EDT 2006
OK, I don't know much about Python, but this is what I get
when I do: ./py.mon start=py0
File "mon.py", line 15, in ?
import wx
File
"/usr/lib/python2.4/site-packages/wx-2.6-gtk2-ansi/wx/__init__.py", line
42, in ?
from wx._core import *
File "/usr/lib/python2.4/site-packages/wx-2.6-gtk2-ansi/wx/_core.py",
line 4, in ?
import _core_
ImportError:
/usr/lib/python2.4/site-packages/wx-2.6-gtk2-ansi/wx/_core_.so: symbol
_ZTV17wxMemoryFSHandler, version WX_2.6 not defined in file
libwx_gtk2_core-2.6.so.0 with link time reference
... so one more dependency to worry about in the future?
Or is this something that can easily be taken care of with a
modified configure script?
Best,
Benjamin
Jachym Cepicky wrote:
> Hallo,
> bugfix version of py.monitor scripts. Some people tested the scripts and
> they found it nice. What about you, developers?
> Current version avaliable on
> http://les-ejk.cz/programs/grass/py.monitor-06-06-14-4.tgz
> tar xzf py.monitor-06-06-14-4.tgz
> cd py.monitor
> py.mon start=py0
> py.rast soils -o
> py.vect roads
> py.erase
> Everything, what should work (all toolbar buttons, etc.) works. Zoom/Unzoom
> avaliable via mouse wheel. Mapcontent manageable via py.* commands (this
> should move to d.* commands in the future) from commandline and via any
> other interface via LOCATION/MAPSET/.pyX file.
> Starting with the morning, I will not have much time and I will not be
> so close to internet for a week, so I will not spam your mailboxes
> for a while.
> It would be good just to send me some note, e.g., that you tryed, but it did
> not work. It is not so easy to develop GUI without any feedback.
> Looking forward
> Jachym
> On Wed, Jun 14, 2006 at 11:34:09AM +0200, Jachym Cepicky wrote:
>>Hallo,
>>after long discussion with Michael and a bit coding, I would like to
>>present new new concept of GRASS monitors.
>>I prepared set of py.* commands, which IMHO *should* became parts of d.*
>>commands. This is just a workaround this.
>>General concept is, each monitor has it's own LOCATION/MAPSET/.pyX file,
>>in which the d.* files are stored. This file is checked from the GUI and
>>if there is some change, it's content serves for creating the map.
>>Advantage of this approach is, that this file can be modified from any
>>GUI/CLI. Target is, to have py.mons *independent* on any UI, however
>>managable from *any* of them.
>>Screenshot can be found on [1], set of new tools can be found on [2].
>>Example session (in xterm) can look like follows:
>>py.mon start=x0
>>py.mon start=py0
>>py.rast soils
>>py.vect roads
>>py.ctrl -l
>>py.ctrl remove=vect
>>py.rast fields -o
>>py.vect fields fcol=yellow
>>py.ctrl -l
>>(see screenshot [1] for details and possible outputs).
>>py.rast and py.vect commands can be used just like the old d.* commands
>>for installation just untar [2] and cd new py.monitor directory
>>[1] http://les-ejk.cz/tmp/py.mon.png
>>[2] http://les-ejk.cz/programs/grass/py.monitor.tgz
>>Please test and discusse.
>>Jachym
>>Jachym Cepicky
>>e-mail: jachym.cepicky at centrum.cz
>>URL: http://les-ejk.cz
>>GPG: http://les-ejk.cz/gnupg_public_key/jachym_cepicky-gpg_public_key.asc
>>OFFICE:
>>GDF-Hannover
>>Mengendamm 16d
>>30177 Hannover
>>Germany
>>e-mail: cepicky at gdf-hannover.de
>>URL: http://gdf-hannover.de
>>Tel.: +49 511-39088507
>>_______________________________________________
>>grass-dev mailing list
>>grass-dev at grass.itc.it
>>http://grass.itc.it/mailman/listinfo/grass-dev
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
