[GRASS-dev] py.monitor: AttributeError: wxFramePtr instance has
no attribute 'Bind'
Stephan Holl
holl at gdf-hannover.de
Fri Jun 16 03:31:50 EDT 2006
Hello Jáchym,
On Thu, 15 Jun 2006 17:53:00 +0200 " Jáchym Čepický"
<jachym.cepicky at centrum.cz> wrote:
> hallo,
> thank you for testing!
> _____________________________________________________________
> > Od: mlennert at club.worldonline.be
> > Komu: Jachym Cepicky <jachym.cepicky at centrum.cz>
> > CC: grass-dev at grass.itc.it
> > Datum: 15.06.2006 11:49
> > Předmět: [GRASS-dev] py.monitor: AttributeError: wxFramePtr
> > instance has no attribute 'Bind'
> >Using the latest version of py.monitor (06-06-14-4), I get the
> >following
> error:
> > > ./py.mon start=py0
> >Traceback (most recent call last):
> > File "mon.py", line 314, in ?
> > main()
> > File "mon.py", line 293, in main
> > pymonitor = Monitor(0)
> > File
> "/usr/lib/python2.3/site-packages/wx-2.4-gtk-ansi/wxPython/wx.py",
> line 1951, in __init__
> > _wxStart(self.OnInit)
> > File "mon.py", line 53, in OnInit
> > self.initToolBar()
> > File "mon.py", line 82, in initToolBar
> > self.frame.Bind(wx.EVT_TOOL, self.toggleButtons,
> > id=self.ID_ZOOMIN)
> >AttributeError: wxFramePtr instance has no attribute 'Bind'
> >and an error window which reads:
> >XRC resource: Cannot create bitmap from 'bitmap'.
> >Moritz
> currently, I'm not sitting by my computer, but I would say, that I
> use wx-gtk 2.6. I use something, what is in debian testing. could you
> try to install python-wxgtk2.6 ? But I'm not shure, it this will
> help :-(
> Sholl: Could you try please and send me the result and your
> configuration? Thanks!
It seems that your needed package python-wxgtk2.6 is not in sarge. on
Sarge I have libwxgtk2.4-python installed, which seems to be the
equivalent.
Anyway, I have the following errors during
./py.mon start=py0
File "py.monitor", line 220, in ?
main()
File "py.monitor", line 200, in main
File "/usr/lib/python2.3/site-packages/wxPython/wx.py", line 1951, in
__init__ _wxStart(self.OnInit)
File "py.monitor", line 41, in OnInit
self.initToolBar()
File "py.monitor", line 66, in initToolBar
self.frame.Bind(wx.EVT_TOOL, self.toggleButtons, id=self.ID_ZOOMIN)
@Moritz: are you on debian sarge as well?
Best
Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl at gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
