[GRASS-dev] py.monitor: AttributeError: wxFramePtr instance has no attribute 'Bind'
Moritz Lennert mlennert at club.worldonline.be
Thu Jun 15 12:22:58 EDT 2006
  Jáchym Čepický wrote:
> hallo, thank you for testing!
> _____________________________________________________________
>> Od: mlennert at club.worldonline.be Komu: Jachym Cepicky
>> <jachym.cepicky at centrum.cz> CC: grass-dev at grass.itc.it Datum:
>> 15.06.2006 11:49 Předmět: [GRASS-dev] py.monitor: AttributeError:
>> Using the latest version of py.monitor (06-06-14-4), I get the
>> following
> error:
>>> ./py.mon start=py0
>> Traceback (most recent call last): File "mon.py", line 314, in ?
>> main() File "mon.py", line 293, in main pymonitor = Monitor(0) File
> "/usr/lib/python2.3/site-packages/wx-2.4-gtk-ansi/wxPython/wx.py",
> line 1951, in __init__
>> _wxStart(self.OnInit) File "mon.py", line 53, in OnInit
>> self.initToolBar() File "mon.py", line 82, in initToolBar
>> self.frame.Bind(wx.EVT_TOOL, self.toggleButtons, id=self.ID_ZOOMIN)
>> and an error window which reads:
>> XRC resource: Cannot create bitmap from 'bitmap'.
>> Moritz
> currently, I'm not sitting by my computer, but I would say, that I
> use wx-gtk 2.6. I use something, what is in debian testing. could you
> try to install python-wxgtk2.6 ? But I'm not shure, it this will help
It does. Installing 2.6 solved the problem. Now I can display both
vector and raster maps at more or less equivalent speeds to the gis manager.
However, when I try to zoom in, I get the following error, once for each
map which is currently displayed:
ERROR: region for current mapset line 1: <n-s resol: 0.000000>
        run "g.region"
Moritz
