[GRASS-dev] lib/vask
Glynn Clements
glynn at gclements.plus.com
Fri Jun 16 11:51:37 EDT 2006
Michael Barton wrote:
> > IOW:
> > i.orpho.photo
> > r.le.setup
> > v.transform
> > etc/set_data
> > etc/support/modhead
> > lib/edit
> > lib/imagery
> > Michael is already working on a v.transform replacement.
> Important clarification. I've done a TclTk GUI wrapper for v.transform. I
> haven't replaced it. I have replaced i.points and i.vpoints.
Good point.
OTOH, the use of vask by v.transform isn't critical; it's only used if
you don't supply either pointsfile= or -s.
For entering a table of points, any decent text editor will be better
than the vask option. Actually, even "ed" is probably better than the
vask option.
