[GRASS-dev] lib/vask
Michael Barton
michael.barton at asu.edu
Fri Jun 16 12:39:17 EDT 2006
Well, the points file is being handled by the georectifier. So no need for
vask there.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Fri, 16 Jun 2006 16:51:37 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <rez at touchofmadness.com>, GRASS Devel <grass5 at grass.itc.it>
> Subject: Re: [GRASS-dev] lib/vask
> Michael Barton wrote:
>>> IOW:
>>> i.orpho.photo
>>> r.le.setup
>>> v.transform
>>> etc/set_data
>>> etc/support/modhead
>>> lib/edit
>>> lib/imagery
>>> Michael is already working on a v.transform replacement.
>> Important clarification. I've done a TclTk GUI wrapper for v.transform. I
>> haven't replaced it. I have replaced i.points and i.vpoints.
> Good point.
> OTOH, the use of vask by v.transform isn't critical; it's only used if
> you don't supply either pointsfile= or -s.
> For entering a table of points, any decent text editor will be better
> than the vask option. Actually, even "ed" is probably better than the
> vask option.
