[GRASS-dev] SHAPElib update in GRASS-CVS
Markus Neteler neteler at itc.it
Sat Jun 17 09:00:50 EDT 2006
I have sync'ed the SHAPELIB copy from OGR in
lib/external/shapelib/
Changes:
dbfopen.c:
 * Revision 1.67  2006/06/17 00:24:53  fwarmerdam
 * Don't treat non-zero decimals values as high order byte for length
 * for strings.  It causes serious corruption for some files.
 * http://bugzilla.remotesensing.org/show_bug.cgi?id=1202
 * Revision 1.66  2006/03/29 18:26:20  fwarmerdam
 * fixed bug with size of pachfieldtype in dbfcloneempty
 * Revision 1.65  2006/02/15 01:14:30  fwarmerdam
 * added DBFAddNativeFieldType
 * Revision 1.64  2006/02/09 00:29:04  fwarmerdam
 * Changed to put spaces into string fields that are NULL as
 * per http://bugzilla.maptools.org/show_bug.cgi?id=316.
 * Revision 1.63  2006/01/25 15:35:43  fwarmerdam
 * check success on DBFFlushRecord
 * Revision 1.62  2006/01/10 16:28:03  fwarmerdam
 * Fixed typo in CPLError.
 * Revision 1.61  2006/01/10 16:26:29  fwarmerdam
 * Push loading record buffer into DBFLoadRecord.
 * Implement CPL error reporting if USE_CPL defined.
 * Revision 1.60  2006/01/05 01:27:27  fwarmerdam
 * added dbf deletion mark/fetch
shpopen.c:
 * Revision 1.48  2006/01/26 15:07:32  fwarmerdam
 * add bMeasureIsUsed flag from Craig Bruce: Bug 1249
 * Revision 1.47  2006/01/04 20:07:23  fwarmerdam
 * In SHPWriteObject() make sure that the record length is updated
 * when rewriting an existing record.
 * Revision 1.46  2005/02/11 17:17:46  fwarmerdam
 * added panPartStart[0] validation
 * Revision 1.45  2004/09/26 20:09:48  fwarmerdam
 * const correctness changes
 * Revision 1.44  2003/12/29 00:18:39  fwarmerdam
 * added error checking for failed IO and optional CPL error reporting
 * Revision 1.43  2003/12/01 16:20:08  warmerda
 * be careful of zero vertex shapes
 * Revision 1.42  2003/12/01 14:58:27  warmerda
 * added degenerate object check in SHPRewindObject()
I have re-applied
 http://bugzilla.remotesensing.org/show_bug.cgi?id=809
Please report any issues.
Markus
