[GRASS-dev] Re: [bug #4450] (grass) g.remove vect: empty dirs in the $MAPSET/.tmp/$HOSTNAME left
Maciek Sieczka werchowyna at epf.pl
Sat Jun 17 13:12:10 EDT 2006
On Sat, 17 Jun 2006 15:04:52 +0200 (CEST)
Markus Neteler via RT <grass-bugs at intevation.de> wrote:
> On Sat, Jun 17, 2006 at 01:32:24PM +0200, Maciek Sieczka via RT wrote:
> > I have built current Grass 6.1 CVS on Ubuntu Breezy with
> > http://mpa.itc.it/markus/tmp/clean_temp2.c apllied.
> > I'd prefer each such empty dir be removed right after 'g.remove
> > vect'is done, but maybe this is not so critical.
> This is an issue of the program creating the vector map in
> question. Which one did you use? A script, r.* or v.*?
It is 'g.remove vect' that leaves empty temp dirs in the .tmp. As my
bug report reads:
>For each vector file it removes, g.remove leaves 1 empty, redundant
>directory in the $MAPSET/.tmp/$HOSTNAME.
To reproduce:
1. Create a vector file
2. Empty your $MAPSET/.tmp/$HOSTNAME entirely.
3. g.remove that vector.
4. See an orphaned empty dir left over.
Maciek
CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej cenie, zapoznaj si? z nasz? ofert?.
ZAPRASZAMY
www.skarpatravel.pl
