[GRASS-dev] d.polar: optional EPS output added
Markus Neteler
neteler at itc.it
Tue Jun 20 13:06:17 EDT 2006
I have added a new "eps=" parameter to d.polar. This
writes the output to an EPS file instead of launching
'xgraph' (which isn't available on all systems by default).
Description:
Draws polar diagram of angle map such as aspect or flow directions
Usage:
d.polar map=name [undef=value] [eps=string]
Parameters:
map Name of raster angle map
undef Pixel value to be interpreted as undefined (different from NULL)
eps Name of optional EPS output file
My colleague Brune Caprile wrote a LISP program for
me to generate the EPS code from the d.polar raw data,
I rewrite it to SHELL :-)
Now you can generate high quality polar diagrams.
Enjoy,
Markus
