[GRASS-dev] [bug #4645] (grass) v.digit under cygwin
Tue Jun 20 22:51:38 EDT 2006
On Tue, 20 Jun 2006 21:32:16 +0200
Maciek Sieczka <werchowyna at epf.pl> wrote:
> On Tue, 20 Jun 2006 19:01:20 +0200 (CEST)
> Request Tracker <grass-bugs at intevation.de> wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=4645
> > 1. under windows and cygwin, only the points into the boundary which
> > centroid is linked to the database table are selected. 2. to make it
> > work, I have to choose the option "next not used" for the two
> > centroids, but the "Form" window freezes during several minutes with
> > the message "Could not set Tcl system encoding to" (utf-8 encoding).
> This looks like this bug report:
> http://intevation.de/rt/webrt?serial_num=4110
> Merging it.
> > (remark : it works very well under linux (fedora core 4))
> Actually the error applies to Linux to, only apparently on Cygwin it
> has more severe consequences.
symptom of the 100% cpu usage problems which still linger in v.digit?
(but less of a problem than before)
Hamish
