[GRASS-dev] lib/symbol/Makefile $(INSTALL)?
Thu Jun 22 07:57:45 EDT 2006
Hamish wrote:
> lib/symbol/Makefile has:
> symb:
>         $(MKDIR) $(ETC)/symbol
>         find ./symbol -type f | grep -v CVS | xargs tar chBf - |(cd $(ETC); tar xBf -)
> this seems very circuitous to me, should it be:
> symb:
> 	$(INSTALL) -m 644 symbol/* $(ETC)/symbol/
> (will "install" include directories?)
1. No, install won't copy directories.
2. All of the entities which the symbol/* pattern matches are
directories. You could use symbol/*/* instead, but that would match
symbol/CVS/* and symbol/*/CVS.
3. The install-sh script doesn't support installing multiple files in
a single command; you need to use a "for" loop or similar.
If you don't want to use "tar" (which has problems, e.g. preserving
ownership and permissions on the copied files), use:
	find symbol -path '*/CVS' -prune -o -type d -print | while read dir ; do \
		$(MKDIR) $(ETC)/"$$dir" ; \
	done
	find symbol -path '*/CVS' -prune -o -type f -print | while read file ; do \
		$(INSTALL_DATA) "$$file" $(ETC)/"$$file" ; \
	done
