[GRASS-dev] Re: [bug #2794] (grass) wish window mouse wheel and TAB
Maciek Sieczka werchowyna at epf.pl
Fri Jun 23 15:28:28 EDT 2006
On Fri, 23 Jun 2006 11:10:29 -0700
Michael Barton <michael.barton at asu.edu> wrote:
> See below
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics & Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> > From: Maciek Sieczka via RT <grass-bugs at intevation.de>
> > Reply-To: Maciek Sieczka via RT <grass-bugs at intevation.de>
> > Date: Thu, 22 Jun 2006 21:14:15 +0200 (CEST)
> > To: <jidanni at jidanni.org>
> > Cc: <grass-dev at grass.itc.it>, <michael.barton at asu.edu>,
> > <cedricgrass at shockfamily.net>
> > Subject: [bug #2794] (grass) wish window mouse wheel and TAB
> > Is done for gis.m.
> > In d.m wheel doesn't work (CVS 2006.06.19), although about a month
> > ago it used
> > to output an error if tried
> > (http://intevation.de/rt/webrt?serial_num=4466).
> > Was it an unseccussfell, then reverted, attempt to support wheel in
> > d.m? Any
> > chances wheel will work in d.m?
> Cedric added scroll wheel support in gis.m. I am not supporting d.m
> for any more upgrades--just bug fixes. If someone else wants to add
> it, that's fine.
Oh, so the http://intevation.de/rt/webrt?serial_num=4466 wasn't a sign
of trying to implement wheel in d.m. Do you know then why dis that
error appear first and then dissapeared after a month, when I checked
for it again?
> > File selection dialogs support wheel nicely.
> > "Options" panel in modules is quite OK, besides modules like
> > v.to.db, where
> > scrolling parameters' selection lists (e.g. v.to.db's "Value to
> > upload", i.e.
> > "option=" parameter) causes the whole panel to be scrolled, instead
> > of the
> > parameters list alone.
> > "Output" panel is mostly scrollable, besides when mouse pointer
> > hovers over
> > the grey belt with icons and command syntax - no scrolling then. If
> > there is
> > not much space between subsequent grey belts, the panel is hardly
> > scrollable
> > at all.
> Cedric is working on the two above.
Cool. So that's why we haven't heard from him lately - hidden and
coding! Good news. Or maybe just tired with fame :)?
> > The TAB key circulates through the "Options" panel OK, only it
> > shouldn't
> > bother stopping at the top icon (strange, why is it pressable?)
> > next to module
> > description and at the bottom icon (the copy-command one).
> If this is layer options, I'll look at it and see if I can change
> this.
Nice, thanks.
> > Nice progress but still stuff missing. What are the plans?
> Except for above (and interactive x11 dependencies in a few
> C-Modules), what is still missing?
d.nviz doesn't start from d.m's icon, only prints "ERROR: Required
parameter <input> not set: (Name of existing raster map)." and help to
the terminal.
http://intevation.de/rt/webrt?serial_num=4138
There are also many bug reports with "gis.m" and "d.m" in the title
still open. Some of them seem still valid I know, some I don't. Some
where never answered by responsible devs. Maybe you and Cedric might be
the best people to know which to close or how to comment them?
Maciek
CIEP?E KRAJE - CIEP?E MORZA. Szukasz atrakcyjnego wypoczynku w przyst?pnej cenie, zapoznaj si? z nasz? ofert?.
ZAPRASZAMY
www.skarpatravel.pl
