[GRASS-dev] i.points, i.vpoints now use G_parser()
Sat Jun 24 10:05:22 EDT 2006
Michael Barton wrote:
> I've written a TclTk replacement to i.points and i.vpoints that is in the
> CVS (look under the file menu). I just need some help from someone to do a
> module that will let me calculate RMS error. There are some other bells and
> whistles I can add, but the RMS error calculations are the main item at the
> moment.
I can do that, if you can tell me how to get the GCPs.
