[GRASS-dev] i.points, i.vpoints now use G_parser()
Michael Barton michael.barton at asu.edu
Sat Jun 24 11:02:36 EDT 2006
They are in a POINTS file: 5 columns,
x,y,e(projected),n(projected),use(1/0).
I'll make the vector POINTS file the same.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Sat, 24 Jun 2006 15:05:22 +0100
> To: Michael Barton <michael.barton at asu.edu>
> Cc: Hamish <hamish_nospam at yahoo.com>, grass5 <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] i.points, i.vpoints now use G_parser()
> Michael Barton wrote:
>> I've written a TclTk replacement to i.points and i.vpoints that is in the
>> CVS (look under the file menu). I just need some help from someone to do a
>> module that will let me calculate RMS error. There are some other bells and
>> whistles I can add, but the RMS error calculations are the main item at the
>> moment.
> I can do that, if you can tell me how to get the GCPs.
