[GRASS-dev] i.points, i.vpoints now use G_parser()
Michael Barton michael.barton at asu.edu
Sat Jun 24 17:59:57 EDT 2006
Thanks much. A couple of questions.
What information does it return and in what format?
Also, will it work with any POINTS file in a $GISBASE/group/[mapname]/
directory?
Finally, does it require the presence of a REF file too--or just needs a
POINTS file? I'm asking this so that I can have it working with vectors too.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Glynn Clements <glynn at gclements.plus.com>
> Date: Sat, 24 Jun 2006 22:07:14 +0100
> To: Michael Barton <michael.barton at asu.edu>, Hamish <hamish_nospam at yahoo.com>,
> grass5 <grass-dev at grass.itc.it>
> Subject: Re: [GRASS-dev] i.points, i.vpoints now use G_parser()
> Glynn Clements wrote:
>>> I've written a TclTk replacement to i.points and i.vpoints that is in the
>>> CVS (look under the file menu). I just need some help from someone to do a
>>> module that will let me calculate RMS error. There are some other bells and
>>> whistles I can add, but the RMS error calculations are the main item at the
>>> moment.
>> I can do that, if you can tell me how to get the GCPs.
> I've added g.transform. Currently:
> 1. It requires an imagery group (I avoided parsing the points file by
> using I_get_control_points()).
> 2. It contains yet another copy of the CRS code.
> 3. I haven't tested it yet.
