[GRASS-dev] [bug #4725] (grass) nviz crashed while volume
visualisation
Hamish
hamish_nospam at yahoo.com
Mon Jun 26 00:25:28 EDT 2006
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4725
> Subject: nviz crashed while volume visualisation
> nviz produced a segfault while volume data visualisation.
> Im using the lates cvs build.
> I have tested this with several locations.
> gdb output of nviz within spearfish60 location:
> nviz volume=g3d_test_map_2_30960
> [r.info]
> r.to.rast3 input="mapcalc_test_map_2_30960" \
> output="g3d_test_map_2_30960"
can you provide some commands to create test raster from standard
spearfish maps?
does it segfault on startup?
what about 'nviz -q' and then load from the Panel->Volume menu?
Hamish
