[GRASS-dev] SUBMITTING_SCRIPTS and SUBIMITTING_TCLTK patches
Hamish
hamish_nospam at yahoo.com
Mon Jun 26 03:15:07 EDT 2006
Maciek Sieczka wrote:
> +++ SUBMITTING_SCRIPTS
> +7. See what input/output variants and options are available for you to
> + use in your script at
> + http://mpa.itc.it/markus/grass61progman/parser_8c-source.html#l00326
perhaps a more permanent or relative location could be pointed to?
e.g. see G_define_standard_option() in lib/gis/parser.c?
> +12. Send solely informational output to stderr, not stdout, e.g.:
> + echo "Done." 1>&2
> +13. In order to prevent your script from being too verbose, redirect command's
> + output to /dev/null, e.g.:
> + g.remove vect="${OUTPUT}_temp" > /dev/null
> + The command's output will be filtered letting only warnings and errors get
> + through.
I think the wording of this could be improved.
12. Send output containing status information to stderr, not stdout. stdout
is reserved for parsable output. e.g.:
echo "$PROG complete." 1>&2
13. Consider redirecting irrelevant stdout of "noisy" modules used in your
script to /dev/null. e.g.:
g.remove rast="${tmp}_${PROG}_$$" > /dev/null
Modules should be sending all error and warning messages to stderr,
so important messages will not be hidden by the muting of stdout.
> 14.
fix whitespace, make reasons for using WIND_OVERRIDE more clear.
Is WIND_OVERRIDE even worthy of mention here?
thanks,
Hamish
