[GRASS-dev] SUBMITTING_SCRIPTS and SUBIMITTING_TCLTK patches
Mon Jun 26 07:26:34 EDT 2006
Hamish wrote:
> > +++ SUBMITTING_SCRIPTS
> fix whitespace, make reasons for using WIND_OVERRIDE more clear.
> Is WIND_OVERRIDE even worthy of mention here?
It should be documented that scripts shouldn't modify the WIND file
unless persistently changing the current region is the script's
intended function.
grep-ing for g.region in the scripts directory suggests that
i.fusion.brovey, i.in.spotvgt, and v.rast.stats should be changed to
use either WIND_OVERRIDE or GRASS_REGION (the latter is cleaner, but
the former is probably easier).
