[GRASS-dev] [bug #4742] (grass) i.fusion.brovey, i.in.spotvgt, v.rast.stats: don't use g.region
Request Tracker grass-bugs at intevation.de
Mon Jun 26 14:59:40 EDT 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4742
Subject: i.fusion.brovey, i.in.spotvgt, v.rast.stats: don't use g.region
Glynn wrote on the grass-dev:
> scripts shouldn't modify the WIND file unless persistently changing the
> current region is the script's intended function.
> use either WIND_OVERRIDE or GRASS_REGION (the latter is cleaner, but
> the former is probably easier).
Maciek
-------------------------------------------- Managed by Request Tracker
