[GRASS-dev] gis.m issues
Hamish
hamish_nospam at yahoo.com
Wed Jun 28 11:04:07 EDT 2006
some GIS.m / menu.tcl issues:
* launch r.digit from gis.m menu with no Map Display open leads to a
<region not set> error.
* d.font in menu.tcl has "execute term d.font" which is wrong. then
complains about can't get socket.. it is looking for an active x
monitor? This doesn't actually need a term at all?
* g.access. Does this really need to run in a term?
* g.gisenv: change to run_panel? currently it runs with "--ui" which
kills output. if run_panel you can't edit, add a second menu item for
that?
* g.region -p, g.version -c are broken. Move g.version to help menu?
Hamish
