[GRASS-dev] gis.m issues
Thu Jun 29 13:28:31 EDT 2006
Hamish wrote:
> some GIS.m / menu.tcl issues:
> * launch r.digit from gis.m menu with no Map Display open leads to a
> <region not set> error.
> * d.font in menu.tcl has "execute term d.font" which is wrong. then
> complains about can't get socket.. it is looking for an active x
> monitor? This doesn't actually need a term at all?
d.font doesn't need a terminal.
> * g.access. Does this really need to run in a term?
No.
> * g.gisenv:  change to run_panel?   currently it runs with "--ui" which
> kills output.  if run_panel you can't edit, add a second menu item for
> that?
g.gisenv uses a weird hack for printing the settings when it is run
without arguments. It should just check for the case where neither
get= nor set= were given.
