[GRASS-dev] vm_allocate error
    Helena Mitasova
    hmitaso at unity.ncsu.edu
    Wed Jun 28 22:38:12 EDT 2006
has anybody seen (or have an explanation) for the following
vm_allocate error
that we got from v.proj when projecting rather large point file on
Mac running recent CVS GRASS
(I was able to run v.proj with the same data on a  FC5 machine
without problem).
We got similar error from v.surf.rst after 86% done on 5000x5000
raster (but I was able
to compute bigger raster on a smaller mac laptop). I am trying to
find out whether it is the data
or something specific to Mac (a 2GB memory machine) or a bug that is
causing this error.
thanks, Helena
GRASS 6.1.cvs (jockeyspft):~ > v.proj input=earl030921oregoni
location=coastll mapset=PERMANENT output=earl030921oregoni
Input Projection Parameters: +proj=latlong +a=6378137 +rf=298.257222101
+no_defs +towgs84=0.000000,0.000000,0.000000
Input Unit Factor: 1
Output Projection Parameters: +proj=lcc +x_0=0.6096012192024384e+06
+y_0=0
+lon_0=79dw +lat_0=33d45'n +lat_1=36d10'n +lat_2=34d20'n +a=6378137
+rf=298.257222101 +no_defs +towgs84=0.000000,0.000000,0.000000
Output Unit Factor: 0.3048006096012192
Creating vector file...
Building topology ...
Registering lines: v.proj(2057) malloc: *** vm_allocate(size=8421376)
failed (error code=3)
v.proj(2057) malloc: *** error: can't allocate region
v.proj(2057) malloc: *** set a breakpoint in szone_error to debug
node.c:48: failed assertion `n'
Abort trap
--- end printout 030921-----
Although the vector was created, I wasn't able to display it.  On the
contrary, I was able to display the 030916 vector despite reporting a
similar error without abortion:
---- error printout 030916---
(v.proj(753) malloc: *** error: can't allocate region
v.proj(753) malloc: *** set a breakpoint in szone_error to debug
v.proj(753) malloc: *** vm_allocate(size=24088576) failed (error code=3)
---- end error printout 030916---
there may be a huge segment in the masked area, but the error message
is not comming from the rst code
v.surf.rst input=L18 layer== dmax=3.0 dmin=1.0 elev=surf500501Lidar
maskmap=MASK zmult=1.0 tension=40.0
smooth=10.0 segmax=20 npmin=120
   86%
WARNING: taking too long to find points for interpolation--please change
          the region to area where your points are. Continuing
          calculations...
v.surf.rst(1340) malloc: *** vm_allocate(size=8421376) failed (error
code=3)
v.surf.rst(1340) malloc: *** error: can't allocate region
v.surf.rst(1340) malloc: *** set a breakpoint in szone_error to debug
code=3)
code=3)
code=3)
ERROR: G_malloc: out of memory
Helena Mitasova
Dept. of Marine, Earth and Atm. Sciences
1125 Jordan Hall, NCSU Box 8208,
Raleigh NC 27695
http://skagit.meas.ncsu.edu/~helena/
On Jun 28, 2006, at 8:24 PM, Helena Mitasova wrote:
> On Jun 17, 2006, at 5:26 AM, Māris Nartišs wrote:
>> Re-posting, as previous mail was larger than lists accept.
>> Hello all GRASSers.
>> GRASS CVS contains new module r.lake. This module can be used to
>> create lake
>> maps if only place and lake level is known. To use this module You
>> need
>> terrain raster map (DEM), water level for lake in same units as
>> DEM values
>> and coordinates for any point in lake.
>> Module uses 3x3 sliding window to fill whole area connected to
>> seed point (can
>> be coordinate pair or already existing raster map) and having
>> height values
>> below water level. Output map will have lake depth in DEM units. More
>> information about module is in help page.
>> I use this module for palaeolake reconstructions based on single
>> shore line
>> measurement. It also can be usefull for reservoir planing,
>> creating maps with
>> scenarios for lake level changes etc. Unfortunately mailing lists
>> does not
>> accept attachments larger than 100kb - no sample images with
>> r.lake in
>> action.
>> Currently this module has some limitations and I ask for help to
>> other GRASS
>> developers to help me to fix them.
>> Most important - module is NOT large file safe.
>> Lake volume calculations work only if DEM is in meters.
>> G_area_of_cell_at_row() always returns cell area in square meters,
>> but I
>> could not figure out how to get information about DEM units. Thus
>> if both are
>> in meters, volume is correct, else not ...
> we have already discussed this in relation to r.slope.aspect which
> has the same problem,
> currently it gives warning when x,y in feet is converted to meters
> so that user
> can check and make sure that the elevation is in meters too.
> There is no place currently in GRASS to store DEM z-units (and
> vertical datum) so it is left to
> the user to make sure that the units are handled correctly (big
> pain here in US where
> feet and meters are about equally common and mixed in various ways).
> I believe that for GRASS7 we should include the vertical datum and
> units information for each location even if we
> do not provide the transformation tools - this should help users
> better manage
> their elevation and volume data and they can use external tools to
> convert the vertical datum
> for the data that they want to import to the datum used in the
> GRASS location.
> For example there is an official open source code for US coastal
> vertical datums conversion
> available here (it is written in Java2 though)
> http://chartmaker.ncd.noaa.gov/csdl/vdatum.htm
> This would not prevent the users to mix misc. vert. and horiz.
> datums and units in their database
> (at their own peril as I have learned the hard way), but it will
> encourage the management
> of data in a well defined coordinate system and units in all 3
> dimensions.
> Helena
> P.S. I would like to add this suggestion to the wiki development
> page - apparently it should go
> under Plans but it does not fit into Overview, should I add it to
> sand box?
> Or should we start a GRASS7 proposals/suggestions/todo section?
>> Thanks to all who helped me to code this module.
>> Any comments, ideas, enhancements - always welcome.
>> Maris Nartiss.
>> grass-dev mailing list
>> grass-dev at grass.itc.it
>> http://grass.itc.it/mailman/listinfo/grass-dev
