[GRASS5] GRASS 3D features query (2nd try)
Markus Neteler
neteler at itc.it
Wed Mar 1 05:41:55 EST 2006
marcos boullón magán wrote:
>2006/2/28, Markus Neteler <neteler at itc.it>:
>>Hi Marcos,
>>On Thu, Feb 23, 2006 at 11:17:47AM +0100, marcos boullón magán wrote:
>>>Hello users/developers,
>>>I'd like to query for the current status of the 3D
>>>characteristics/features/capabilities/objects implementation... Are
>>>they finally usable? All the documentation I found is
>>>but I prefer confirmation that this is not a problem linked to
>>>outdated documentation.
>>Would you mind to tell us where you found it so that we can
>>update? In fact it's not too outdated, but could be written
>>a bit better.
>No problem. In the CVS contents on March 1st, I can find it in file
>grass6/lib/vector/html/index.html, section "Vector library Topology
>management", subsection "topo file format". Starting with "[detailed
>docs missing]", the full information on 3D is one sentence long:
>"Face and kernel are 3D equivalents of boundary and centroid, but
>there is no support (yet) for 3D topology (volumes). The only current
>use of face is possibility to display vertical planes in NVIZ."
Marcos,
I have changed that to:
Face and kernel are 3D equivalents of boundary and centroid, but there
-is no support (yet) for 3D topology (volumes). The only current use of
-face is possibility to display vertical planes in NVIZ.
+is no support (yet) for 3D topology (volumes). Faces are used in a
+couple of modules including NVIZ to visualize 3D buildings and other
+volumetric figures.
More text is obviously desired...
markus
