[GRASS5] JGrass 2.0 released
Andrea Antonello andrea.antonello at gmail.com
Sun Mar 5 11:58:29 EST 2006
Hi Maciek,
> > - enhanced native GRASS command execution
> >      - r.proj
> >      - r.dem2contour
> >      - v.contour2dem
> Is there any documentation about v.contour2dem? What interpolation
> method does it use?
v.contour2dem does nothing new to what advanced users like you are already do.
It is a facility method made of the GRASS commands, i.e. it does things every
GRASS user does to get the dem from a shapefile:
- v.in.ogr
- v.to.rast
- r.surf.contour
Therefore the same problems that you found with GRASS apply to this module.
v.contour2dem is just an gui.
> Is it able to produce a hydrologically sound DEM?
> (If not, does JGrass provide functionality for such purpose at all?)
It does the filling of depressions but it doesn't have algorythms for novalue
wholes inside the basin, if that is what you mean.
Is that what you mean?
Cheers
Andrea
____________________________________________________________________________
HydroloGIS - Environmental Safety Modelling
www.hydrologis.com
Andrea Antonello
Environmental Engineer
mobile:  +393288497722
"Let it be as much a great honour to take as to give learning,
if you want to be called wise."
Skuggsja' - The King's mirror - 1240 Reykjavik
