[GRASS5] Re: v.digit odd attribute behavior
Radim Blazek radim.blazek at gmail.com
Mon Mar 6 08:25:57 EST 2006
On 3/6/06, Kirk R. Wythers <kwythers at umn.edu> wrote:
> On Mar 6, 2006, at 3:07 AM, Radim Blazek wrote:
> > On 3/3/06, Kirk R. Wythers <kwythers at umn.edu> wrote:
> >> Radim,
> >> I would like to hear your thoughts concerning what appears to be
> >> fairly odd behavior in v.digit. First some background.
> >> I am working with some vectors that were digitized by students using
> >> ESRI products. The students then saved their work as shape files. I
> >> am double checking their work and using v.digit (6.1.cvs) to make a
> >> few edits (where my interpretation is a little different from theirs)
> >> and add attributes to areas.
> >> The vector is connected to a single table in postgresql.
> >> In 90% of the cases were I select a centroid, or line, or an area,
> >> the expected results get printed to for form which pop up.
> >> However, in a few cases, when I select a centroid, the form pops up
> >> with 3 tabs at the top (Layer 1, Layer 1, Layer2)
> >> The two layer 1 tabs will different information in the fields
> >> (including different cat values), and the layer 2 tab, says "Database
> >> connection not defined"
> > This is all correct. v.in.ogr must clean the topology but it
> > preserves all input data. In this case there were 2 overlaping
> > areas in the input. GRASS created one topologicaly clean
> > area (without overlaps) linked to 2 records (original attributes of
> > the 2 areas).  Those are the 2 tabs for Layer 1.
> > Because this happens quite often when a shapefile is imported
> > and in most cases it means errors (overlaps) in input data
> > v.in.ogr adds for convenience a new layer 2 with number
> > of categories in Layer 1. Using Layer 2 it is very easy
> > to visualize and identify all errors in the input data.
> > Radim
> Thanks Radim,
> In this case, one of the "Layer 1s" is just plain wrong and the best
> thing to do is delete it. I thought to use db.droptable, but that
> command is not available (has it been removed?). Additionally, since
> the second Layer 1 is not a "real" table in postgres. I don't see
> that it would work anyway.
There is onle ONE layer 1, but TWO records.
You just need to delete the record and category
on the centroid using 'Delete' button in 'Display categories'
windows or 'Delete' button in attibutes windows in QGIS.
Radim
> I think the question here is... Is there a way to correct someone
> else's accidental double coding of a polygon by removing the
> offending layer?
> Kirk
> >> g.list shows the vector name to be "test",
> >> v.info shows 1 dblink. and the -c option shows:
> >> GRASS 6.1.cvs (minnesota_utm):~ > v.info -c test
> >> Displaying column types/names for database connection of layer 1:
> >> INTEGER|cat
> >> INTEGER|id
> >> CHARACTER|type
> >> CHARACTER|class
> >> GRASS 6.1.cvs (minnesota_utm):~ > v.info -c test layer=2
> >> Displaying column types/names for database connection of layer 2:
> >> ERROR: Database connection not defined
> >> Any idea what might have happened? or how to get rid of the ghost
> >> layer1?
> >> Thanks,
> >> Kirk
