[GRASS5] [bug #4140] (grass) Nviz doesn't start either from GUI or command line in 6.1cvs generic binary snapshot
Michael Barton michael.barton at asu.edu
Mon Mar 6 23:04:29 EST 2006
A research assistant in my lab reported an identical issue and solved it
today with a symlink to a newer version of libtif I believe. I don't KNOW
that this is the problem, but is sounds suspiciously similar. Of course I
can't remember the details of the symlink or which version of libtif. So I'm
copying him here.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Maciek Sieczka <werchowyna at epf.pl>
> Date: Mon, 6 Mar 2006 17:54:22 +0100
> To: Markus Neteler <neteler at itc.it>
> Cc: <grass-bugs at intevation.de>, <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] [bug #4140] (grass) Nviz doesn't start either from GUI
> On Mon, 6 Mar 2006 15:18:49 +0100
> Markus Neteler <neteler at itc.it> wrote:
>> On Mon, Mar 06, 2006 at 01:08:36PM +0100, Request Tracker wrote:
>>> this bug's URL: http://intevation.de/rt/webrt?serial_num=4140
>>> Subject: Nviz doesn't start either from GUI or command line in
>>> Platform: GNU/Linux/x86
>>> grass obtained from: Trento Italy site
>>> grass binary for platform: Downloaded precompiled Binaries
>>> GRASS Version: 6.1cvs binary 2006-03-04
>>> Upon typing nviz on command line and selecting an elevation raster
>>> in the nviz GUI, the green status bar builds to 100% but nothing
>>> happens afterward. The message box area of the nviz GUI reads:
>>> Update elev null mask
>>> Loading Data
>>> translating colors from fp
>>> but no other errors are indicated. The exact same behavior is
>>> observed if nviz is run from the display manager GUI.
>> Eric,
>> can you please post the related
>> g.region -p
> Also please try running your NVIZ command from the CLI and see what
> happens. I just suppose there might be a segfault, which will be not
> visible in the GUI output.
> Maciek
> http://www.visanen.pl/  - Zapakujemy wszystko!
> Produkcja i dystrybucja torby foliowe, papierowe, reklam?wki, opakowania
> kartonowe, ekskluzywne pude?ka
