[GRASS5] [bug #4140] (grass) Nviz doesn't start either from GUI
or command line in 6.1cvs generic binary snapshot
Maciek Sieczka
werchowyna at epf.pl
Mon Mar 6 11:54:22 EST 2006
On Mon, 6 Mar 2006 15:18:49 +0100
Markus Neteler <neteler at itc.it> wrote:
> On Mon, Mar 06, 2006 at 01:08:36PM +0100, Request Tracker wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=4140
> > Subject: Nviz doesn't start either from GUI or command line in
> > Platform: GNU/Linux/x86
> > grass obtained from: Trento Italy site
> > grass binary for platform: Downloaded precompiled Binaries
> > GRASS Version: 6.1cvs binary 2006-03-04
> > Upon typing nviz on command line and selecting an elevation raster
> > in the nviz GUI, the green status bar builds to 100% but nothing
> > happens afterward. The message box area of the nviz GUI reads:
> > Update elev null mask
> > Loading Data
> > translating colors from fp
> > but no other errors are indicated. The exact same behavior is
> > observed if nviz is run from the display manager GUI.
> Eric,
> can you please post the related
> g.region -p
Also please try running your NVIZ command from the CLI and see what
happens. I just suppose there might be a segfault, which will be not
visible in the GUI output.
Maciek
http://www.visanen.pl/ - Zapakujemy wszystko!
Produkcja i dystrybucja torby foliowe, papierowe, reklam?wki, opakowania kartonowe, ekskluzywne pude?ka
