[GRASS5] RE: [bug #4140] (grass) Nviz doesn't start either from GUI or CLI
Patton, Eric
epatton at nrcan.gc.ca
Mon Mar 6 13:06:45 EST 2006
Maciek,
Perhaps there's another clue here; when I run nviz from CLI, I get:
GRASS 6.1.cvs (Cheticamp):~ > nviz elevation=Cheticamp98.5.ave.fill
Loading Data
Update elev null mask
Loading Data
translating colors from fp
*Segmentation fault*
(my emphasis)
Same error occurs with different rasters.
Hmmm....g.region -p gives:
GRASS 6.1.cvs (Cheticamp):~ > g.region -p
projection: 1 (UTM)
zone: 20
datum: ** unknown (default: WGS84) **
ellipsoid: wgs84
north: 5176119.54768
south: 5166572.33329
west: 628593.997416
east: 652873.00618
nsres: 9.92433928
ewres: 10.10362412
rows: 962
cols: 2403
Nothing too unusual here?
~ Eric.
-----Original Message-----
To: epatton at nrcan.gc.ca
Sent: 3/6/2006 11:54 AM
Subject: [bug #4140] (grass) Nviz doesn't start either from GUI
On Mon, 6 Mar 2006 15:18:49 +0100
Markus Neteler <neteler at itc.it> wrote:
> On Mon, Mar 06, 2006 at 01:08:36PM +0100, Request Tracker wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=4140
> > Subject: Nviz doesn't start either from GUI or command line in
> > 6.1cvs generic binary snapshot
> > Platform: GNU/Linux/x86
> > grass obtained from: Trento Italy site
> > grass binary for platform: Downloaded precompiled Binaries
> > GRASS Version: 6.1cvs binary 2006-03-04
> > Upon typing nviz on command line and selecting an elevation raster
> > in the nviz GUI, the green status bar builds to 100% but nothing
> > happens afterward. The message box area of the nviz GUI reads:
> > Loading Data
> > but no other errors are indicated. The exact same behavior is
> > observed if nviz is run from the display manager GUI.
> Eric,
> can you please post the related
> g.region -p
Also please try running your NVIZ command from the CLI and see what
happens. I just suppose there might be a segfault, which will be not
visible in the GUI output.
Maciek
