[GRASS5] RE: [bug #4140] (grass) Nviz doesn't start either from
GUI or CLI
Maciek Sieczka
werchowyna at epf.pl
Mon Mar 6 15:45:14 EST 2006
On Mon, 6 Mar 2006 14:06:45 -0400
"Patton, Eric" <epatton at nrcan.gc.ca> wrote:
> Maciek,
> Perhaps there's another clue here; when I run nviz from CLI, I get:
> GRASS 6.1.cvs (Cheticamp):~ > nviz elevation=Cheticamp98.5.ave.fill
> Loading Data
> Update elev null mask
> Loading Data
> translating colors from fp
> *Segmentation fault*
> (my emphasis)
A segfault. I suppose devs would not mind it if you could provide a
stacktrace. See here for guiding if you don't mind doing this (for this
purpose, it would be good if your Grass was not built with any
optimisations nor stripping).
http://www.qgis.org/index.php?option=com_content&task=view&id=74&Itemid=58
> Same error occurs with different rasters.
> Hmmm....g.region -p gives:
> GRASS 6.1.cvs (Cheticamp):~ > g.region -p
> projection: 1 (UTM)
> zone: 20
> datum: ** unknown (default: WGS84) **
> ellipsoid: wgs84
> north: 5176119.54768
> south: 5166572.33329
> west: 628593.997416
> east: 652873.00618
> nsres: 9.92433928
> ewres: 10.10362412
> rows: 962
> cols: 2403
> Nothing too unusual here?
Right. What if you set your region extent and res to integer values?
Maight be a silly idea, though try it. And what does g.region -3 say?
Maciek
http://www.visanen.pl/ - Zapakujemy wszystko!
Produkcja i dystrybucja torby foliowe, papierowe, reklam?wki, opakowania kartonowe, ekskluzywne pude?ka
