[GRASS5] Layers Clarification
Radim Blazek
radim.blazek at gmail.com
Tue Mar 7 02:43:21 EST 2006
On 3/6/06, twiens <twiens at interbaun.com> wrote:
> > The possibility to keep in a database the relation between
> > geometry objects in a map and more tables/records was
> > considered during the development of GRASS 6.0. It does
> > not appear to be better solutin because all the geometry
> > processing is done in files. Example: Say that we have
> > one layer with 2 loverlapping lines linked to 2 records in
> > one table.
> > 1
> > +-----------------------+ 2
> > Now we want to clean data and remove the duplicated part,
> > we run v.clean tool=break,rmdupl result (in current
> > implementation):
> > 1 1,2 2
> Are you indicating by this example that within a single
> layer a geographic object can have more than one link to a
> table, or is the result of this operation two layers?
More links to a table.
Radim
> T
> Trevor Wiens
