[GRASS5] Layers Clarification
Moritz Lennert
mlennert at club.worldonline.be
Tue Mar 7 04:21:53 EST 2006
Radim Blazek wrote:
> On 3/6/06, twiens <twiens at interbaun.com> wrote:
>>>The possibility to keep in a database the relation between
>>>geometry objects in a map and more tables/records was
>>>considered during the development of GRASS 6.0. It does
>>>not appear to be better solutin because all the geometry
>>>processing is done in files. Example: Say that we have
>>>one layer with 2 loverlapping lines linked to 2 records in
>>>one table.
>>> 1
>>>+-----------------------+ 2
>>>Now we want to clean data and remove the duplicated part,
>>>we run v.clean tool=break,rmdupl result (in current
>>>implementation):
>>> 1 1,2 2
>>Are you indicating by this example that within a single
>>layer a geographic object can have more than one link to a
>>table, or is the result of this operation two layers?
> More links to a table.
I mùust be very dense, but then what does this have to do with layers ?
Everything you do above is in one layer, or ?
Moritz
