[GRASS5] [bug #4142] (grass) sql statemts in d.m
Moritz Lennert
mlennert at club.worldonline.be
Tue Mar 7 09:36:48 EST 2006
Kirk R. Wythers wrote:
> Hi Maciek,
> Sorry for taking so long in response.
> On Mar 6, 2006, at 3:34 PM, Maciek Sieczka via RT wrote:
>> Kirk wrote:
>>> I may have found a bug in d.m. However, I may not be issuing the sql
>>> statement properly in d.m. For example If issue the following
>>> command on the command line:
>>> d.vect test fcolor=none where="type='JAPI'"
>>> the expected polygons are displayed.
>>> However, in d.m, if I type in the SQL where statement field:
>>> "type = 'JAPI'"
>>> which I believe is the same command minus the (where=) that worked
>>> on the command line, no vectors are displayed. Console output is as
>>> follows:
>>> d.vect map=test color=0:0:0 lcolor=0:0:0 fcolor=none display=shape
>>> type=point,line,boundary,centroid,area icon=basic/x size=5 layer=1
>>> lsize=8 xref=left yref=center llayer=1 {where="type = 'JAPI'"}
>>> Am I misusing the sql field in d.m, or should this be working?
>> If you put type = 'JAPI' (no " ") in d.m it should work, does it?
> Yes, single quotes work. However, without double quotes is it possible
> to do a complex query?
> For example: type = 'JAPI' and 'SP' does not work, and adding the
> double quotes like this: "type = 'JAPI' and 'SP'" does not work either.
This should be type='JAPI' and type='SP'.
As far as I know, type='JAPI' and 'SP' is not standard SQL.
Moritz
