[GRASS5] [bug #4155] (grass) d.m will not display remotely
Request Tracker
grass-bugs at intevation.de
Wed Mar 8 13:39:03 EST 2006
this bug's URL: http://intevation.de/rt/webrt?serial_num=4155
Subject: d.m will not display remotely
Platform: Mac OSX
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 6.1.cvs
d.m is no longer displaying when started remotely through ssh -X. d.mon x0 seems ok, it fires up
the expected display window with the message:
GRASS 6.1.cvs (minnesota_utm):~ > d.mon x0
using default visual which is TrueColor
ncolors: 16777216
Graphics driver [x0] started
However, d.m or d.m & result in the following message:
GRASS 6.1.cvs (minnesota_utm):~ > X Error of failed request: BadAtom (invalid Atom parameter)
Major opcode of failed request: 20 (X_GetProperty)
Atom id in failed request: 0xb5
Serial number of failed request: 11
Current serial number in output stream: 11
For what it is worth gis.m seems to behave in the same mannor:
GRASS 6.1.cvs (minnesota_utm):~ > gis.m
-------------------------------------------- Managed by Request Tracker
