[GRASS5] [bug #4155] (grass) d.m will not display remotely
Glynn Clements
glynn at gclements.plus.com
Wed Mar 8 23:05:14 EST 2006
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4155
> Subject: d.m will not display remotely
> Platform: Mac OSX
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: 6.1.cvs
> d.m is no longer displaying when started remotely through ssh -X. d.mon x0 seems ok, it fires up
> the expected display window with the message:
> GRASS 6.1.cvs (minnesota_utm):~ > d.mon x0
> using default visual which is TrueColor
> ncolors: 16777216
> Graphics driver [x0] started
> However, d.m or d.m & result in the following message:
> GRASS 6.1.cvs (minnesota_utm):~ > X Error of failed request: BadAtom (invalid Atom parameter)
> Major opcode of failed request: 20 (X_GetProperty)
> Atom id in failed request: 0xb5
> Serial number of failed request: 11
> Current serial number in output stream: 11
> For what it is worth gis.m seems to behave in the same mannor:
> GRASS 6.1.cvs (minnesota_utm):~ > gis.m
I'm guessing that this is an issue with "wish". It's impossible to say
any more than that based upon the above details; atom 0x5b (91) isn't
predefined (only 1 through 68 are predefined).
Can you run wish by itself (or any other Tcl/Tk programs) remotely?
