[GRASS5] [bug #4155] (grass) d.m will not display remotely
Thu Mar 9 01:07:01 EST 2006
> this bug's URL: http://intevation.de/rt/webrt?serial_num=4155
> Subject: d.m will not display remotely
> Platform: Mac OSX
> grass obtained from: CVS
> grass binary for platform: Compiled from Sources
> GRASS Version: 6.1.cvs
> d.m is no longer displaying when started remotely through ssh -X.
> d.mon x0 seems ok, it fires up  the expected display window with the
> message:
> GRASS 6.1.cvs (minnesota_utm):~ > d.mon x0
> using default visual which is TrueColor
> ncolors: 16777216
> Graphics driver [x0] started
> However, d.m or d.m & result in the following message:
> GRASS 6.1.cvs (minnesota_utm):~ > X Error of failed request:  BadAtom
> (invalid Atom parameter)
>   Major opcode of failed request:  20 (X_GetProperty)
>   Atom id in failed request:  0xb5
>   Serial number of failed request:  11
>   Current serial number in output stream:  11
> For what it is worth gis.m seems to behave in the same mannor:
> GRASS 6.1.cvs (minnesota_utm):~ > gis.m
> X Error of failed request:  BadAtom (invalid Atom parameter)
lastest CVS works fine for me between two Debian/GNU/Linux/i686 machines.
haven't tested on a Mac though.
Hamish
