[GRASS5] v.extrude segfaulting
Markus Neteler neteler at itc.it
Thu Mar 9 13:09:13 EST 2006
Jachym Cepicky wrote:
>Hallo,
>v.extrude segfaults on line 178
>    Vect_hist_copy (&In, &Out);
>Removing this line helps, though I do not know, if that is the best
>sollution..
Jachym,
my fault - fixed in CVS. The position of that function should be *after*
opening
the input map...
Markus
