[GRASS5] error in v.example for grass61
marcos boullón magán
marcosboullon at gmail.com
Thu Mar 9 15:00:38 EST 2006
Please,
Could someone with write access to grass61 CVS update the v.example code?
In line 49, file
grass6/doc/vector/v.example/main.c
please change
Vect_check_input_output_name ( inopt->answer, outopt->answer, GV_FATAL_EXIT );
to
Vect_check_input_output_name ( old->answer, new->answer, GV_FATAL_EXIT );
Thanks
-- marcos boullón magán
